-   D3 - Wheels and Tyres (https://forum.a8parts.co.uk/forumdisplay.php?f=51)
-   -   20" tyre sizes (https://forum.a8parts.co.uk/showthread.php?t=9263)
madcjd 10th December 2014 11:52 AM
20" tyre sizes
Hi.
Finally off to view/buy those 20" alloys, previously mentioned, on Sunday.
I just thought I'd do the maths on the tyre sizes...........
My current tyres (255/40 18) give a rolling circumference of 207.7 CM.
The new tyres (265/40/20) give a rolling circum of 226.2 CM......Unless I've done my maths wrong!
This is quite a difference!
Has anyone here jumped from 255/40/18 to a similar sized (265/40) on a 20" wheel, or have they opted for a smaller profile to get the circumference closer.
Or...........is it not an issue in the whole scheme of things?
Obviously, the speedo would under read a tad.
HPsauce 10th December 2014 12:22 PM
Is this for the D2 or D3? 255/40R18 seems small for either......
ScottD3 10th December 2014 01:18 PM
http://www.willtheyfit.com/
What's the width of the wheels?
That plays on what tyres you fit.
255/45/18 is the correct size for the D3s with 8j wheels.
The fuel cap lists the correct sizes for each size OEM alloys for D3s.
madcjd 10th December 2014 05:26 PM
You're absolutely right!
I put 255/40/18 because they are the tyres (on genuine RS6 rims) that I currently have for sale - I've brainwashed myself!!
So - thanks for pointing that out. The car is a D3 and the tyres are 255/45/18.
This makes the circumference 215.76 cm, which closes the gap a tad.
madcjd 10th December 2014 05:30 PM
Hi.
Just corrected my previous mistake re tyre size - oops!
The car I have is a D3 and the potential 20" rims are 9" wide. The tyres already fitted to them are 265/40/20.
These are D4 alloys so will require a spigot ring to take up the bigger wheel bore.
Borys 10th December 2014 08:31 PM
I have 255/35 on 8.5J and 295/30 on 10J
I think 275/35 was original audi spec tyre for 20" wheels
Lee S 11th December 2014 11:56 AM
Yep... 275/35/20 or I think the S8 was fitted with 265/35/20. Either will fit a 9" rim. +++
Lyons 12th December 2014 12:33 PM
I opted for 275/35's. Higher profile for more comfort and 5mm less arch gap!
