Old 15th April 2016, 09:06 AM
G113 is under the bonnet, on the end of the air box under the scuttle drain cover
Bought one last week from TPS as mine is showing the same fault. Just waiting for a replacement plastic drive gear for it as its not incl with a new motor but is only a couple of quid but on back order. Can't see me getting the old one off the motor undamaged!
Be warned it ain't cheap, but I couldn't see the point in replacing with a used one from a car that's most likely older and higher miles than mine.
Unfortunately the new ones aren't production date marked on the unit, only the box, so difficult to tell
