G113 is under the bonnet, on the end of the air box under the scuttle drain cover
Bought one last week from TPS as mine is showing the same fault. Just waiting for a replacement plastic drive gear for it as its not incl with a new motor but is only a couple of quid but on back order. Can't see me getting the old one off the motor undamaged! Be warned it ain't cheap, but I couldn't see the point in replacing with a used one from a car that's most likely older and higher miles than mine. Unfortunately the new ones aren't production date marked on the unit, only the box, so difficult to tell
Thanks for your answers.
![]() Presumably the worst that will happen if I leave it for a while will be that I keep hearing the clicking noise and air won't always go where is meant to?! If new ones aren't cheap from TPS then I'm sure the dealer will want more!
Cars... '93 Audi Coupe 2.0 Alpine White (sold) '99 Audi S4 Merlin Purple - K04 upgrade to 412hp (sold) '00 Audi S8 Agate Grey (Sold ![]() '11 Audi Q7 4.2tdi Unknown Red (Classic Red Pearl Effect - thanks MJ) |
One's inside the car have an 'a' on the end of the pet number. The one in the engine bay is different and doesn't have the a suffix
Can look out part number and price when I'm home tonight? From memory £120
See this post that Adrian and I commented on:
http://forum.a8parts.co.uk/showthread.php?t=4786 Please find two attached screenshots from ELSAWIN. PM me if you want access to my ELSAWIN running under Virtualbox, and I'll let you remote in, if that helps?
I think (if I remember correctly) that there are 4 motors on each side of the console, plus the other one that Adrian mentioned under the bonnet which seems to be a different part. Don't take this as gospel, but judging from all my rummaging around, the 4 motors seem to be similar. I ordered one from the forum sponsors in order to replace my faulty clicky-clicky unit.
Just like IT said, you can normally feel the clicking if you place your hand on each motor in turn if you're unable to echo locate it like a dolphin lol - that's exactly what I had to do in my case.
I have not had any issues with them on 8 so far but I had 3 of them fail on A6 1 shortly after another, first it was intermittent but gradually got worse. I don't think they are the same on 6 and 8 but very similar. I took them off to investigate and found that because they are sealed units they had a lot of carbon dust build up in side from the wear of carbon brushes. The brushes and slip rings were still in good condition, it's just that all the wear dust was either shorting out or preventing good connection. I cleaned them up, greased bearings and gears with fresh grease and re-assembled, worked as new since without any problems. So if they are £120 each new it might be worth checking to see if the old ones are serviceable. Or if you buy second hand it could be a good idea to give them overhaul before putting in the car.
That sounds a very sensible approach
![]() If someone wants my used one after removal to see if they can resurrect it I'm happy to post it at cost The drive gear is on back order from Germany so it'll be a couple of weeks before I swap mine over
