Old 24th November 2016, 07:29 PM
No the plugs are out and I didn't quite line up the camera, but looking down into the cylinder the top of the piston looks "wrong" - lots of shiny bits!
That's not necessarily as bad as one might think. I had a cam belt go and all 16 inlet valves connected with the pistons. There is a photo of the piston tops on here somewhere after I polished them during the rebuild. 16 new inlet valves later the engine was once again running and in use. The valves are designed to bend on impact to protect the piston crowns. If the engine needs a new home?
