Old 13th May 2010, 01:16 PM
Zip's Avatar
Zip Zip is offline
Angry
Originally Posted by ulfilias View Post
Ok....I'm with you, Zip all the way on the screaming....Mine will not come out and has broken the sensor inside the hole. Looks like it was a magnetic bar inside a white plastic sheath, inside a black plastic sheath. The Aluminium has exfoliated (Like rust, Aluminium does oxidise, particularly in the presence of water) and trapped the plastic shaft/sheath inside.
I am slowly chiseling away the plastic as i can't think of anything else to do. Maybe remove the drive shaft (*panic*) and push it out.....At this rate i can almost see me needing a new arm !!!
I recognise the "exfoliating".... bit like layers off an onion peeling off in the hole. I was loathed to clean it out too rigorously in case I left a load more swarf in there.
Apparently replacing is a right royal PITA, as the cable runs back to the control unit are a nightmare to trace. Someone on audipages has soldered on new sensors to existing cables....do a search.
Hope I never have to touch the little f***ers ever again... and all that for the TINIEST little bit of black plastic that was caught on the end of the sensor corrupting the readings. I suspect a compressed air hose into one of the wheel bolt holes would have been just as effective...
Still got to drill out that caliper bolt though....arrrggh.
Zip
