Old 13th May 2010, 11:58 AM
ulfilias ulfilias is offline
Ok....I'm with you, Zip all the way on the screaming....Mine will not come out and has broken the sensor inside the hole. Looks like it was a magnetic bar inside a white plastic sheath, inside a black plastic sheath. The Aluminium has exfoliated (Like rust, Aluminium does oxidise, particularly in the presence of water) and trapped the plastic shaft/sheath inside.
I am slowly chiseling away the plastic as i can't think of anything else to do. Maybe remove the drive shaft (*panic*) and push it out.....At this rate i can almost see me needing a new arm !!!
Irritatingly my elsawin is showing the old style for my car. Quite odd.
sensor seems to be 0 265 006579....Where is the part number ???
Ta,
Lee
