Old 8th December 2016, 03:03 PM
I find that that error is always in ABS unless you press brake pedal after switching on ignition. So try that- switch ignition on, press and release brake, connect VCDS and scan ABS for fault codes, brake switch error should not be there.
That's weird - never had to do that with mine? Maybe it's a PF thing?
