Old 14th February 2017, 05:47 PM
Originally Posted by speed_demon1978 View Post
Hi Julian - I can`t see an option for changing the units in the car menu at all. Only get a few options to change like speed (in mph or km) etc.
In the instrument cluster the fuel consumption is displaying as xx l/km (l/100km) which I can`t seem to change.
In the hidden menu I get this under the MMI settings (see attached pic)
I was referring to the changes you can make in the 'Setup/Measurement Units' MMI Menu. This has a 'Distance Unit' and 'Speed'. If you have 'Distance' set to "miles" and 'Speed' to "MPH" then your 'l/km' in the cluster is a different problem I'm not able to help you with.
I think you're going to need a VCDS scan anyway, as to really try and check these two issues out, members of this forum will want to see part numbers, HW/SW versions and coding settings of the Instrument panel and door ECUs to make progress ...
Julian
