Old 14th February 2017, 05:47 PM
Originally Posted by speed_demon1978 View Post
Hi Julian - I can`t see an option for changing the units in the car menu at all. Only get a few options to change like speed (in mph or km) etc.
In the instrument cluster the fuel consumption is displaying as xx l/km (l/100km) which I can`t seem to change.
In the hidden menu I get this under the MMI settings (see attached pic)
I was referring to the changes you can make in the 'Setup/Measurement Units' MMI Menu. This has a 'Distance Unit' and 'Speed'. If you have 'Distance' set to "miles" and 'Speed' to "MPH" then your 'l/km' in the cluster is a different problem I'm not able to help you with.
I think you're going to need a VCDS scan anyway, as to really try and check these two issues out, members of this forum will want to see part numbers, HW/SW versions and coding settings of the Instrument panel and door ECUs to make progress ...
Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver.
Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years!
