Old 29th April 2017, 09:18 PM
That sounds about right. I find it so strange that so much fuel is left when range and fuel sensor reads zero. Unless its needed to save the fuel pump, but why so much?
I only ever ran out once in my D3, I had done about 50 miles some of which were towing a trailer since the tank showed zero, and then it only ran out as I was going up hill!!!!! Started up when I put a gallon in that I had in the boot, probably the only time I got more than 90 litres in that fill!
There is a big margin for sure, and I suspect the tank and filler is marginally more than 90L also
