Old 25th July 2017, 02:56 PM
Might just be corroded connections at the blower end.
I've never had a problem with the blower yet (touch Myrtle) so I don't know how easy it is to get to the connector (blower is just at the rear of the engine bay, is it not?). If it's easy to access I'd get a meter on the connector next ... see if you get a voltage there.
I've taken the mesh cover off and with the intake flaps open (they close on recirculate) I can see two connectors, one pink and one beige. Both have at least one seriously thick cable in them.
My suspicion is that one relates to the auxiliary coolant pump and the other to the blower.
Based on this rather old post by me (about my PF in 2011) I'd say the pink (purple?) one was the pump and beige one the blower:
Bonnet up this morning, turned on "rest" and it was immediately obvious where all the plumbing etc. was, just to the nearside of the air intake.
There are 2 connectors right there, a "yellowish" one to the front and a "purplish" one by the windscreen, both just held by clips.
No tools needed, took maybe 30 seconds. Disconnecting the purple one stopped the pump.
Note that on the FL model there is only one connector (beige/yellow) visible by the pump and to disconnect the pump I cut (and insulated) the relevant wires; I suspect the connector has just moved a few inches so is less obvious/accessible.
