My suspicion is that one relates to the auxiliary coolant pump and the other to the blower. Based on this rather old post by me (about my PF in 2011) I'd say the pink (purple?) one was the pump and beige one the blower: Quote:
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 25th July 2017 at 03:05 PM. |
It does look like it's the beige connector, judging by images such as this: https://i.imgur.com/5bmLvyn.jpg
If that connector is clean, perhaps try giving the blower a tap/spin as Marty suggests. Brushes certainly sounds a plausible explanation. If it starts working after giving it a nudge, I'd suspect warn brushes is your problem.
Indeed it does, and we have lift off!
![]() While you were posting this I took the intake mesh cover off again and tried to work out which was which then attempted to access the beige one. As I tried to pull it from it's retaining clips I heard a very slow gentle soft thud. The blower motor ticking over extremely slowly driven by the solar panel. And sure enough a bit of wiggling and it got a bit faster. Into the car, ignition on and we're blowing again, a bit hesitant but the problem is identified. Thanks very much for the information and suggestions Mark. I now need to undo that connector and make sure it's clean and making good contact. ![]() PS In case anyone has the noisy coolant pump issue it looks like the pink/purple connector in there is almost certainly the one to undo to disable the pump. ![]()
Well, I really don't understand this.
![]() Opened up the connector, all looked good, joined it up again and nothing. A bit of wiggling, still nothing, then just moved it a bit to try and prod the motor and suddenly it's all working. ![]() Currently it's back in it's mounting clips, appears properly joined, and is all working OK. Trouble is there's almost no slack to work with and just a small gap through the intake flaps to work in. My suspicion is that somehow one of the (thick) cables isn't terminated properly onto the contacts inside one half the connector as the mating surfaces look fine. I think I might buy a connector pair, make up a short lead to bridge the two halves and try to work out which side is suspect.
You could try squashing the pins (very slightly) too to make them a tighter fit. Had a similar problem with my washer motor recently. The connector seemed fine and it worked again when I dismantled half of the car to get to it. Put everything back and the damn thing stopped working again. After stripping the car down again I found that wiggling the wires didn't affect it but pushing on the connector did. So I gave the pins a light squeeze with long-nose pliers and that seemed to fix it.
Failing that, it's probably a bad connection where the wires attach to the pins, as you suggested, but it should be possible to determine if it is that by wiggling/pushing/pulling them.
I've already done what I can to tighten the pin/contacts.
Lobbed an email to our sponsors to see if they can supply a pair of connectors (ideally with pigtails) so I can test/experiment a bit more and decide what exactly is giving an intermittent connection. I guess it could even be at the motor end, which would be beyond my personal capabilities I think.
If you can't get the connectors, to save cutting wires you could make up a couple of connector 'bypass' leads using 'bed of nails' test clips to determine if the problem is at the connector or the motor.
http://www.ebay.co.uk/itm/1pair-Angl...-/281896808055 http://uk.rs-online.com/web/p/products/7148281/
