Old 21st June 2018, 04:49 AM
Chip2786 Chip2786 is offline
Are these cars OK to disconnect the batteries to or is there a chance the electrics can play up? I know they probably throw up ghost faults but that's not a problem. If they are safe to disconnect then I would perhaps try that first?
I wouldn’t if you can avoid, my car went mental when the battery went flat. It threw up about 30 odd fault codes. They all cleared but scared the schnitzel out of me!
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
