Old 5th October 2018, 10:15 AM
lebesset lebesset is offline
Is the CEL on? I would expect it would be for something like that.
As there are two, the ECU is probably using the other one to interpolate cam timing for both banks so it will still run. It won't be using the variable cam timing though since it won't have a feedback mechanism for it.
tks mikki
no , no engine light [ presume that's what CEL means ]
didn't know the D2 5v engine had separate cam timing for each bank
can I safely just leave it as is ? does it mean an ECU renewal to fix it ? sounds expensive to me !
