Is the CEL on? I would expect it would be for something like that.
As there are two, the ECU is probably using the other one to interpolate cam timing for both banks so it will still run. It won't be using the variable cam timing though since it won't have a feedback mechanism for it. |
no , no engine light [ presume that's what CEL means ] didn't know the D2 5v engine had separate cam timing for each bank can I safely just leave it as is ? does it mean an ECU renewal to fix it ? sounds expensive to me ! |
Exhaust cam timing is fixed, but it can vary the inlet cam timing using the tensioner.
Surprised the light isn't on actually. Its simple enough to change the sensors though and they're not expensive. G40 I think is the right hand bank (check though!). You can get to it by removing the air intake pipe between the filter box and throttle body. Edit - mixing up sides ![]() ![]() Last edited by MikkiJayne; 5th October 2018 at 06:33 PM. |
will put it on my to do list ....is it my imagination or is there always a to do list on a D2 ? logical on an 18 year old car I suppose ! incidentally mikki , in the audiklub instructions about the 40v engine it says that if the G40 fails the 163 in the other bank will generate a signal to replace it......presumably that means that if the 163 fails the G40 can't reciprocate ! Last edited by lebesset; 6th October 2018 at 10:18 AM. Reason: addendum |
Interesting. I would expect it would also run from G40 on its own. The inline engines with just a single sensor have G40 so I think that one is the primary for Motronic. I might give it a try and see how it behaves. Simple enough to unplug G163 and reset any codes it throws up.
incidentally , you don't happen to know offhand the part number of the G163 ? am having trouble to identifying it here in france.... in case I ever need it ![]() |
Same as the G40, up there ^^. They're both the same part
