Old 6th October 2018, 06:45 PM
Interesting. I would expect it would also run from G40 on its own. The inline engines with just a single sensor have G40 so I think that one is the primary for Motronic. I might give it a try and see how it behaves. Simple enough to unplug G163 and reset any codes it throws up.
Old 7th October 2018, 01:03 PM
lebesset lebesset is offline
look forward to seeing the result of your test if and when you get round to it !
incidentally , you don't happen to know offhand the part number of the G163 ? am having trouble to identifying it here in france.... in case I ever need it
Old 7th October 2018, 06:08 PM
Same as the G40, up there ^^. They're both the same part
Old 16th November 2018, 01:45 PM
well , got round to ordering the G40
being a tyro I have no idea where the top of the timing belt cover is !!
presumably I have to take the cover off the engine and the timing belt cover is right there in view on the uk drivers side
tried to find a picture but no luck !
Old 16th November 2018, 03:10 PM
Behind this cover:
You'll need a T30 Torx bit to remove the sensor. Torque is 10Nm.
Old 16th November 2018, 08:08 PM
yet again thanks mikki
tyro or not I have both a set of torx and a torque wrench !
Old 15th December 2018, 11:42 AM
don't know what a g40 costs in the uk [ less for sure ] but in france the cheapest is €18 delivered ! hate to think what it costs from audi!
quick look at flea bay and found one in china and decided to risk it , nearly a month to deliver [ as stated ] , came yesterday , installed as per mikki's instructions [ she must have small fingers to get the screws out ] , couple of sticking plasters for the back of my hand , out with the computer et voila ......all correct !
not bad for €3 delivered !
