Old 21st December 2019, 10:15 AM
C4R 100N's Avatar
C4R 100N C4R 100N is offline
Default Looks like no. Most of the back. But not of the connector...
Did you happen to get a larger pic of the whole back of the airbag, and also the connector?
I didn't think to capture the connector....
If i disconnected the airbag then I would have to clear a code, no?
I have a cheap ebay cable and vwtool but am reluctant to disconnect in case I get an airbag light in the cluster which I am unable to extinguish... If you could reassure or guide me then I could be persuaded to disconnect the airbag connector from the steering wheel.
Did you want a view of the connector unconnected? Showing the pins?
I will go down fighting on this one. This car should be enjoyed and not mothballed or destroyed!
1998 D2 S8 Jaspis Green
