Old 9th June 2020, 02:34 PM
I don't want to dismantle that as it's working
To get at the switch unit:
1. Remove the transparent window and take out the festoon bulbs. Optionally remove the map/reading light bulbs too.
2. Lever out bus bars carefully (there are a couple of plastic lugs to push aside for the big one)
If you want to lift out the PCB and switch block it's held in by the big black plastic clips either side - very easy to push them back to release, any old blunt blade should do.
