Thread: New key
Old 28th July 2020, 11:13 AM
Coding a new key from scratch requires the immobiliser pin which is non-trivial to get.
Unless you already have it on scratch-off tag, which I actually do for my S8!
It looks like this (image courtesy of Ross-Tech):
Just use the old key with immo chip, it should still be working and starting car, I assume it's just remote not locking/unlocking doors and get a new remote:
So is the immobiliser chip in the key section, so you can just replace the remote locking part? Dead simple if it is.
Coding in a new remote is very simple, all described in the Ross-Tech wiki. Though there's a finite number (5 maybe?) so you can run out.
I think I did it when I got my current S8, erased all the remotes (requires VCDS) then just added the two I had.
