The D2 chip is the glass one and can't be moved to another key as it is epoxied in place. Coding a new key from scratch requires the immobiliser pin which is non-trivial to get. Audi just plug it in to the mothership and it happens automagically, but aftermarket tools are available to extract it. VCDS can't code it without the pin.
I can't remember the company name of Neil's locksmith either, but he did keys for a few of us at the 2018 meet. |
Just use the old key with immo chip, it should still be working and starting car, I assume it's just remote not locking/unlocking doors and get a new remote: https://www.ebay.co.uk/itm/VW-AUDI-4...da28%7Ciid%3A1
It looks like this (image courtesy of Ross-Tech): ![]() Quote:
![]() Coding in a new remote is very simple, all described in the Ross-Tech wiki. Though there's a finite number (5 maybe?) so you can run out. I think I did it when I got my current S8, erased all the remotes (requires VCDS) then just added the two I had.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 28th July 2020 at 12:47 PM. |
Craig Nettleton is the chap Neil uses I have his number as 07900 600 548 or email craigynett @ gmaildotcom
Cars... '93 Audi Coupe 2.0 Alpine White (sold) '99 Audi S4 Merlin Purple - K04 upgrade to 412hp (sold) '00 Audi S8 Agate Grey (Sold ![]() '11 Audi Q7 4.2tdi Unknown Red (Classic Red Pearl Effect - thanks MJ) |
![]() I had my key handy so popped it apart, leaving the remote part away from the car. Unlocked the drivers door with the blade, alarm didn't go off. Inserted key and started car. Result. ![]() Try that, I think you probably have a cheap and simple solution as suggested by Ainars, if cleaning doesn't work. ![]()
Monday morning came and wife drove car to her work using her key. She went into work and I set about driving to mine, except the car kept dying out after starting. Tried it about a dozen times and then phoned Audi, as the car had got this far. He suggested the key might be faulty and to try another one. Got wife's key and got to work. Called into Audi later on to check key and have it coded again, only to find that the transponder was missing from inside!
I had the opposite issue in my Murple. The monkey who fitted the alarm and remote-start tried getting the transponder out of one key and destroyed it in the process, so then cut up the other key and taped it to the reader coil so the remote-start worked
![]() ![]() I feel a call to Craig the locksmith in my future... |
Will VAG Tacho extract the SKC on these? I managed it on an '04 Leon, bought an ID48 chip ad programmed it myself with VCDS
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
FL D2 has immo built in instrument cluster, as far as I know there are no cheap tools available that will do it offline, you are looking at either £1000 tool or need VAG PC or ODIS with online and GEKO access. You can buy GEKO access on aliexpress for single use or for a day if you have VAG PC or ODIS.
Tags |
key |
