  #57
Old 14th March 2021, 07:44 PM
Back on the Green Beast Its been at Mike's for a month or so as it really needs the oil leaks sorting before being put back in to service, so there was no point in it going home then coming straight back.
One unpleasant surprise when the front panel came off - it appears to have suffered an impact on the lower right corner which has also damaged the radiator We were assuming that the escaping coolant was the oil cooler pipe, but alas also the radiator too. I'll get a replacement front panel from Prestige, and a new radiator.
Engine out
Its been out before, as there are a few tell-tales like wire routing and cable ties in odd places. The sensor ground wire was just chilling out behind the cylinder head!
and the left engine mount wasn't connected. The ECU didn't seem to mind about either
A three-fer here. The knock sensor plugs are toast, as usual. The vacuum pipes are all shredded, as usual. Not as usual though, the header tank t-piece snapped as soon as I touched it. Tbh I'm always pleasantly surprised when these don't snap, so I will replace this with a metal piece.
One of the heater hoses is badly distended. This wouldn't have lasted much longer so hopefully I'll have one in the box of pipes. These are NLA now though.
Engine and box on the separating table.
I'll split these tomorrow and start cleaning them up. Apart from the radiator, this one is pretty much all the usual suspects
ID:	25790   Click image for larger version
ID:	25791   Click image for larger version
ID:	25792   Click image for larger version
ID:	25793   Click image for larger version
ID:	25794   Click image for larger version
ID:	25795   Click image for larger version
ID:	25796   Click image for larger version
