Back on the Green Beast
![]() One unpleasant surprise when the front panel came off - it appears to have suffered an impact on the lower right corner which has also damaged the radiator ![]() Engine out Its been out before, as there are a few tell-tales like wire routing and cable ties in odd places. The sensor ground wire was just chilling out behind the cylinder head! and the left engine mount wasn't connected. The ECU didn't seem to mind about either ![]() A three-fer here. The knock sensor plugs are toast, as usual. The vacuum pipes are all shredded, as usual. Not as usual though, the header tank t-piece snapped as soon as I touched it. Tbh I'm always pleasantly surprised when these don't snap, so I will replace this with a metal piece. One of the heater hoses is badly distended. This wouldn't have lasted much longer so hopefully I'll have one in the box of pipes. These are NLA now though. Engine and box on the separating table. I'll split these tomorrow and start cleaning them up. Apart from the radiator, this one is pretty much all the usual suspects ![]() |
I’ve been racking my brain regarding the busted radiator and I can think of two scenarios which could have caused that;
1. Shortly after [ahem] slamming the car on the coilovers, the wife caught the front of the bumper on a high kerb. When she reversed the lower bumper was completely bent out of shape and the bumper was out of alignment. I had to take the bumper off and get the heat gun out and manipulate it back to shape as best as possible before reattaching it. 2. Not long before point 1 above, I had the car jacked up on the widow maker jack. I was applying some silver hammerite to the rusty brake disc centres for cosmetic purposes. Whilst finishing up the last of the front discs the jack folded like cheese and the front of the car came down on the deck. Due to the angle I was parked at the front nearside was semi resting on a kerb and the full weight of the car was on that one side for about 30 minutes until my mate turned up with a jack. Both front wheels were completely off the car and I didn’t have one underneath like I normally would. I think it was the wife though! ![]()
I can understand why they are called the widow maker ,when I had the d2 i went to change a flat wheel in the car port ( very smooth concrete floor) i had car jacked and remove studs put my hands on top of the wheel and give it a pull and down came the car ,it was that close that I instantly looked at both hands to see how many fingers we're missing ,but fortunately for my they the back of them were just skinned were the wing had rubbed them against the back of the wheel ,(I bought a trolley Jack after that)
With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black |
Hmm. I wonder if this is why the left engine mount was disconnected? It fell apart when I touched it.
Got the engine and box split, but thats it tonight. I was going to mount the gearbox on the stand, but realised I had repurposed the M12 hardware I normally use for this on something else recently and had forgotten to replace it ![]() I'll get some more hardware tomorrow and carry on. |
Lest me get this straight, so the engine mounts have a circuit to them?
Is this normal? Why would an engine mount link to the diagnostics? Purely for my learning ![]()
They are active mounts. The solenoid on the side opens up a valve to an air pocket inside the rubber. With it open the mount is softer as it just depends on the rubber. With it closed, the mount is stiffer as it also contains an air spring.
Normally the ECU will show an error code if the mounts are open circuit, but it wasn't in this case so I'll investigate that and make sure its behaving. |
I’m impressed the D2 had such tech back then
![]() I only have a plug in OBD2 reader that connects to my phone and it only shows the basic codes such as the omission of cats which triggers an EML every few hundred miles (I rarely bother clearing them anymore), however I vaguely remember my friend telling me before I had my cats removed that an engine mount was flagging up in his scanner but it wasn’t leaking...so he left it ![]() I wonder if this was that. That was about 3 years ago at least.
