Old 20th July 2023, 09:20 PM
monkeyboyuk monkeyboyuk is offline
Oh I’ve seen those files and I’ve read the manual to try see what differences there were to my d3 etc.. I had that for over 7 years and knew it inside out. The differences in suspension aren’t that many between d3/d4. I’m on the hunt for coding etc to check. The tyre/wheel sizes I’d checked Against the door sticker
A friend and I have already reset the suspension to factory to see if that helped any just in case someone had been messing about. And we have since lowered via vcds which in a small way seemed to help slightly with the handling and ride, although I do still get the car skipping across the road sometimes especially on full lock
Well, a good starting point for troubleshooting is to actually read the manual and follow the steps in it, you can find the suspension one in this thread:
http://forum.a8parts.co.uk/showthread.php?t=8379
And then compare the factory coding/tyre size/spec to yours etc and make sure its all correct.
There's lots of dodgy VCDS people around that will lower your car with vcds for £80 to make it 'stanced' and all that, and you just can't know what the previous owner's lifestyle choices were
2021 Q7 4M, 3.0tfsi MHEV Black Edition
1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting…. ** FOR SALE **
1990 2.3 20v 7a Coupe Quattro
**SOLD** 2014 D4, FL 3.0tdi, phantom black, sport exec lwb
