Old 16th June 2011, 08:07 PM
Botang Botang is offline
Thats basically the same charger as mine, but expect it to be very hard to fit, it Might not even clear the bonnett with that inlet manifold on it. As Singh said mine is a 32v which is very different from yours, I believe your inlet ports are flat where as mine are angled.
5-6psi is doable as its the same principle that MTM, PES and the likes use.
