Old 16th June 2011, 08:07 PM
Botang Botang is offline
Thats basically the same charger as mine, but expect it to be very hard to fit, it Might not even clear the bonnett with that inlet manifold on it. As Singh said mine is a 32v which is very different from yours, I believe your inlet ports are flat where as mine are angled.
5-6psi is doable as its the same principle that MTM, PES and the likes use.
Old 16th June 2011, 08:13 PM
yes well i did pdf a format for everything il see if i can find it maybe it will help with things
but yes i think a low boost application is a good place for me to start of course its all going to take months to come together but i can think of nothing better than showing up at one of the future meets with a supercharger on a 40v v8 thats got to be a rarity in the a8 and s8
Old 16th June 2011, 08:20 PM
A few more pics for you
ID:	2012   Click image for larger version
ID:	2013   Click image for larger version
ID:	2014   Click image for larger version
ID:	2015   Click image for larger version
Old 16th June 2011, 10:18 PM
very nice pictures there i can see now how you have modified the standard intake, i would not mind seeing this in the flesh and taking note of how its al come about ect... as this is somthing i will be doing before the end of this year
Old 17th June 2011, 11:58 AM
RanjS8 RanjS8 is offline
Default supercharger
i am just in awe.....
this is an incredible achievement...would love to see a step by step how to on this!!!!!!!
Old 17th June 2011, 06:05 PM
Thats what the pictures are,
1) get a big cutting tool
2) remove half the engine
3) do a bit of welding
4) fit it all back together
5) Pray it works
Old 22nd June 2011, 01:30 PM
Curtis's Avatar
Curtis Curtis is offline
i have been thinking of doing the same to mine. i have the same 32v abz motor. but the gearbox has been a big worry for me. have you done anything to the gearbox. what are the limits on the gearbox?
Old 22nd June 2011, 06:25 PM
the gear box will take the power no problem you just need to get a remap by a good tuner so they can map it so it dose not give max torque until higher in the rev range and gears its the torque that will kill the box so if you can tame it then its fine :-)
