There are 2 fuel level senders one on each side. If it cuts out again open the one on left, it is easier and check if there is fuel in tank on that side. If it is empty then one or both senders are giving wrong readings, if there is fuel on left side then jet suction pumps are not working and not pumping fuel to the other side most likely because something is not seated properly.
