Old 10th November 2011, 12:45 PM
Basically this bit is the question:
Are there variations in the numbers of pins connected at the plug depending on how many twiddly bits there are in the mirror electrics that would make it easy enough to check if they're correct or not? Any obvious fittings for the auto dip function that aren't present on non-dipping mirror?
I basically need to know if it's possible to ID the correct mirror based on its physical appearance/wiring to confirm it is the part number I need.
If you could post a pic of the spare you have (especially if it's without mirror glass) and the wiring plug pins then that would help as I can compare to what I've been offered.
Mine's a facelift though, so may be different.....
Adrian
