Old 28th July 2012, 08:31 AM
^^^^ What he said. Check the fuel filter Also remember that thefuel pump is a technical marvel and actually dosen't pump fuel from the tank to the fuel rai rail; it pumps fuel from the tank to a seperate chamber in the fuel pump assembly and thence to the fuel rail. If this chamber drys out the pump has the devils own job to refill itself as it uses some of the fuel to drive the turbine pumps in the tanks that send the fuel to the chamber!!!!!!! Try pouring 5 lts into the tank from a can before starting as this floods the chamber before running into the bottom of the tank.
Audi desined it this way to overcome the 2 low poins in the tank either side of the prop shaft. It keeps the weight distribution equal in unequal volumes of the tank low points.
