Old 28th July 2012, 08:31 AM
^^^^ What he said. Check the fuel filter Also remember that thefuel pump is a technical marvel and actually dosen't pump fuel from the tank to the fuel rai rail; it pumps fuel from the tank to a seperate chamber in the fuel pump assembly and thence to the fuel rail. If this chamber drys out the pump has the devils own job to refill itself as it uses some of the fuel to drive the turbine pumps in the tanks that send the fuel to the chamber!!!!!!! Try pouring 5 lts into the tank from a can before starting as this floods the chamber before running into the bottom of the tank.
Audi desined it this way to overcome the 2 low poins in the tank either side of the prop shaft. It keeps the weight distribution equal in unequal volumes of the tank low points.
Old 28th July 2012, 07:09 PM
The car has been fine today, used it several times and started perfectly as normal. Tomorrow I'll be leaving it where I am now in Hertfordshire for 2 weeks whilst at home in Dorset, I am then off work for a week and will try and get some minor issues sorted with the 8 whilst I am on holiday back here in Hertfordshire. The 8 is not usually left for more than a couple of days, the current situation is quiet unique.
Old 28th July 2012, 07:55 PM
I would take a can with a few litres and pour it in just prior to starting as CtL has suggested and that will hopefully prevent the same happening again when you get back
Old 29th July 2012, 09:44 AM
There is no reason why fuel would escape baffle housing while car is standing for a while unless it's cracked in which case it would not take week but it would leak out much more quickly. And would only affect if there is less then 1/3 of tank.
I don't think messing with can is the way to do it. When you switch on ignition fuel pump runs for 2-3 sec to prime the system. Just cycle ignition 5-6 times for 3-5 secs each time to get some fuel in system before starting. You would do the same after work done on fuel system like changing filter or fuel pump etc.
