Originally Posted by tallon
AWD though? or maybe it doesn't matter... mine would be the 5hp19FLA fwd version
so hopefully the newer 2000 4.2L A8 is similar electronically
I just wanted to be sure before tearing the car apart :\
Architex did your trans need to be replaced or something? I was looking for aftermarket parts to make it stronger since the 4.2 probably has even more torque. Not exactly familiar with what parts are weak, though.
Yes the fourth gear started slipping after the MAF sensor had gone wrong so important to do a scan and check that too regularly. Box failed at 122k miles and the thread about it is HERE
