Old 22nd August 2012, 09:32 PM
Originally Posted by tallon View Post
AWD though? or maybe it doesn't matter... mine would be the 5hp19FLA fwd version
so hopefully the newer 2000 4.2L A8 is similar electronically
I just wanted to be sure before tearing the car apart :\
Architex did your trans need to be replaced or something? I was looking for aftermarket parts to make it stronger since the 4.2 probably has even more torque. Not exactly familiar with what parts are weak, though.
Yes the fourth gear started slipping after the MAF sensor had gone wrong so important to do a scan and check that too regularly. Box failed at 122k miles and the thread about it is HERE
Old 22nd August 2012, 10:23 PM
tallon tallon is offline
thanks guys for the info
someone else told me I should be good in a light car as well which makes me feel a little better about it, I'm going to try to not add too much weight as I'm still working on the chassis. I think I'm going to get the upgraded D Drum since it's the piece that is always breaking for others. I wish there were more upgraded aftermarket parts. It seems I'll never be able to increase power of my car with this trans.
this is the aftermarket part they're saying is stronger
http://www.youtube.com/watch?v=L3fD-lYHpdA&feature=plcp
reverse d drum brakes where it's holding snap ring and clutch pack. Does this affect other gears or just reverse? I don't see where else is an issue as far as it being weak.
