Old 5th September 2012, 11:50 AM
wiingg wiingg is offline
Originally Posted by sloss View Post
Using a Mulitmeter set to the beeper alarm just touch each visible end of the fuse while it's in position, it should beep: no beep = duff fuse/connection.
Don't hold it on for long as, depending on type of meter, you may complete the circuit and have current going through the meter.
As you are checking a small part within a circuit there will be no shorting or problem caused elsewhere
I've tested all the fuses and they all had continuity across them. I checked for wiring diagrams in elsawin but couldn't find anything.
Has anyone got any wiring diagrams associated with the glovebox light wiring?
