Old 5th September 2012, 11:50 AM
wiingg wiingg is offline
Originally Posted by sloss View Post
Using a Mulitmeter set to the beeper alarm just touch each visible end of the fuse while it's in position, it should beep: no beep = duff fuse/connection.
Don't hold it on for long as, depending on type of meter, you may complete the circuit and have current going through the meter.
As you are checking a small part within a circuit there will be no shorting or problem caused elsewhere
I've tested all the fuses and they all had continuity across them. I checked for wiring diagrams in elsawin but couldn't find anything.
Has anyone got any wiring diagrams associated with the glovebox light wiring?
Old 5th September 2012, 12:02 PM
sloss's Avatar
sloss sloss is offline
Something just occurred to me so I went out to my car to check....
You need at least the side lights on before the Glovebox one will work
Old 5th September 2012, 09:24 PM
That's that one sorted then!! I just assumed it would work all the time as did the one in my previous car
