Thread: W12 Service
Old 23rd October 2012, 07:28 AM
david@a8parts david@a8parts is offline
Director at A8 Parts
OK, so my shopping list went like this:
W12 Specific Parts:
12x Spark Plugs Part No 101905600A
1x Oil Filter 07C115562E
1x Sump Plug N90813202
2x Air Filters 4E0129620D
10 Litres ATF Oil G055162A2
Gearbox Filter 09E325429
Gearbox Gasket 09E321371
D3 Generic:
1x Fuel Filter 1J0201511A
1x Pollen Filter 4E0819439A
To Change the spark plugs you need to remove the upper section of the inlet manifold (as per photos) and as such the correct proceedure is to replace the gasket when you refit it. I didnt bother with this because my gaskets looked fine (they are actually part metal so quite robust) and they cost around £70 each.
Check the back of your service book for the recall stamps and see if there is mention of the coil pack recall - its sure to have been done by now on your car, it was quite a few years ago. If you cant do that call any Audi garage and they chould be able to check if there are any outstanding recalls on your car. The updated part number is 07C905715A so if all else fails have a look at them when you get the manifold off.
Fuel filter is located just in front of the offside rear wheel. There is a small section of undertray which you will need to remove to gain access to it. The fuel lines are connected via two plastic clip on fittings so you just have to depress the white plastic clip (you fat bitch ) and the fitting will slide off the filter. BEWARE the fuel will be under pressure so get ready for a petrol shower, or at least have some rags handy. After that its one bolt that holds the filter in a plastic cradle, remove refit and job done.
At Work to Break:
2001 TT 8N 1.8T Quattro with a loud exhaust!
2000 A8 D2 3.7Q Non Sport Ming Blue
1999 A8 D2 4.2Q Non Sport Santorin Blue
2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather
2001 A2 1.4 TDi
2006 A6 C6 2.4 Quattro Avant Canyon Red
At Work to Drive:
1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch
1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash
2008 Fiesta Sportvan x2
2002 Transit 2.4 LWB
2007 VW Crafter Recovery Truck
2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart
2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses.
At Work to Hire:
4x 6 Berth Sunlight Motorhomes
