OK, so my shopping list went like this:
W12 Specific Parts: 12x Spark Plugs Part No 101905600A 1x Oil Filter 07C115562E 1x Sump Plug N90813202 2x Air Filters 4E0129620D 10 Litres ATF Oil G055162A2 Gearbox Filter 09E325429 Gearbox Gasket 09E321371 D3 Generic: 1x Fuel Filter 1J0201511A 1x Pollen Filter 4E0819439A To Change the spark plugs you need to remove the upper section of the inlet manifold (as per photos) and as such the correct proceedure is to replace the gasket when you refit it. I didnt bother with this because my gaskets looked fine (they are actually part metal so quite robust) and they cost around £70 each. Check the back of your service book for the recall stamps and see if there is mention of the coil pack recall - its sure to have been done by now on your car, it was quite a few years ago. If you cant do that call any Audi garage and they chould be able to check if there are any outstanding recalls on your car. The updated part number is 07C905715A so if all else fails have a look at them when you get the manifold off. Fuel filter is located just in front of the offside rear wheel. There is a small section of undertray which you will need to remove to gain access to it. The fuel lines are connected via two plastic clip on fittings so you just have to depress the white plastic clip (you fat bitch ![]() ![]()
At Work to Break: 2001 TT 8N 1.8T Quattro with a loud exhaust! 2000 A8 D2 3.7Q Non Sport Ming Blue 1999 A8 D2 4.2Q Non Sport Santorin Blue 2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather 2001 A2 1.4 TDi 2006 A6 C6 2.4 Quattro Avant Canyon Red At Work to Drive: 1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch 1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash 2008 Fiesta Sportvan x2 2002 Transit 2.4 LWB 2007 VW Crafter Recovery Truck 2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart 2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses. At Work to Hire: 4x 6 Berth Sunlight Motorhomes |
