Thread: Missing
Old 17th November 2012, 10:32 AM
sounds like a faulty idle control valve as per the scan Dezzy
The Idle control Valve (basically) controls the amount of air let into the inlet manifold when on idle. The valve has a 'Pin' which moves in and out incredibly fast, meaning the engine idle can be controlled accurately.
Common symptoms of a faulty Idle Air control Valve (IAC) are:
Poor idling (you would never have guesed!)
Cutting out when the engine speed drops (approaching bends, roundabouts etc)
High revving on idle
Idle speed going up and down
A diagnostic machine will sometimes point out the IAC is faulty, however, not always.
Sounds like it might be sticking even after youve cleaned it
