Old 17th November 2012, 10:32 AM
sounds like a faulty idle control valve as per the scan Dezzy
The Idle control Valve (basically) controls the amount of air let into the inlet manifold when on idle. The valve has a 'Pin' which moves in and out incredibly fast, meaning the engine idle can be controlled accurately.
Common symptoms of a faulty Idle Air control Valve (IAC) are:
Poor idling (you would never have guesed!)
Cutting out when the engine speed drops (approaching bends, roundabouts etc)
High revving on idle
Idle speed going up and down
A diagnostic machine will sometimes point out the IAC is faulty, however, not always.
Sounds like it might be sticking even after youve cleaned it
Old 18th November 2012, 09:09 AM
Thanks Neil
She's let me down again, won't restart and has been abandoned out on a little village in the sticks.
Same again missing popping and then won't run. Seemingly when up to temp no issues when it was cold or warming and again no faults recorded. Could the idle valve cause this when not at idle?
Just would not run on any throttle position.
How long after an AA call out should you leave it before having a car fire?
Old 18th November 2012, 10:18 AM
Idle control valve would only affect idle/low throttle. Possibly crank position/speed sensor.
Old 19th November 2012, 06:45 AM
Thanks Ainars.
She totally refused to fire up yesterday, but i couldn't start top strip it down where it's dumped.
I wondering if it's fuel related, pump maybe
Old 20th November 2012, 06:59 AM
graynada graynada is offline
I must admit pump crossed my mind. I don't think i had any fault codes when mine went. Try running a feed direct (fused of course ) direct to the pump to see if you can hear it running.
Old 20th November 2012, 11:01 AM
Would the position sensor/speed sensor throw a code? I'm happier in a way that she won't run now as it should be easier to find the fault (fingers crossed) that said i'm still open to hear other reasons to non starting.
Old 20th November 2012, 11:27 AM
47p2's Avatar
47p2 47p2 is offline
Crank position sensors usually fail when hot, so in theory it would start when cold even if it was faulty.
Nite Blue 3.0L SE Quattro
