Originally Posted by oldnick
but the real bummer I found in a post by ...The_Laird ....re fitting a towbar , in which he says that even if it is fitted with the OE towbar [ yes, it is by wesfalia ] you have to cut a bit out of the bumper cover anyway because the swan neck doesn't pass low enough!
clearly my man has just butchered it a bit more!
Fitting a genuine Audi D2 towbar does not require a cut to the rear bumper, however there is a plastic plate on the underside that is either cut or more often just removed altogether .....
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
