Old 21st November 2012, 08:10 PM
Originally Posted by oldnick View Post
but the real bummer I found in a post by ...The_Laird ....re fitting a towbar , in which he says that even if it is fitted with the OE towbar [ yes, it is by wesfalia ] you have to cut a bit out of the bumper cover anyway because the swan neck doesn't pass low enough!
clearly my man has just butchered it a bit more!
Fitting a genuine Audi D2 towbar does not require a cut to the rear bumper, however there is a plastic plate on the underside that is either cut or more often just removed altogether .....
Old 21st November 2012, 08:39 PM
oldnick oldnick is offline
clicking on quote doesn't seem to work !
does this apply to both the one piece AND the two piece bumper covers ?
seems that TL owned a 2 piece which had a bit chopped out ...hopefully he will return on the subject ; I presumed it must be a mistake when they changed the design
Old 22nd November 2012, 07:06 AM
My 2002 2.8 had a factory-fitted detachable tow bar and had a slight cut-out on the lower bumper. When I made numerous enquiries for fitting a towbar to my S8, I was told by a few fitters that the Westfalia version did require a cut-out. But Ian is usually right!
The one I have (make escapes me just now) does not require a cut-out but it is visible below the lower bumper.
Old 22nd November 2012, 08:25 AM
david@a8parts david@a8parts is offline
Director at A8 Parts
Usually, but not always....
The factory towbar does require a small cut out in the lower valance of the bumper as per the Westfalia/Audi installation instructions. It only needs to be about 5cm long and 1cm deep.
The rear undertray also has to be cut down in size to allow access to the ball connection.
At Work to Break:
2001 TT 8N 1.8T Quattro with a loud exhaust!
2000 A8 D2 3.7Q Non Sport Ming Blue
1999 A8 D2 4.2Q Non Sport Santorin Blue
2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather
2001 A2 1.4 TDi
2006 A6 C6 2.4 Quattro Avant Canyon Red
At Work to Drive:
1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch
1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash
2008 Fiesta Sportvan x2
2002 Transit 2.4 LWB
2007 VW Crafter Recovery Truck
2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart
2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses.
At Work to Hire:
4x 6 Berth Sunlight Motorhomes
Old 22nd November 2012, 06:13 PM
tks all for clearing that up!
as the bumper has to be 'modified ' anyway , am going to see if I can design a repair with a cut out which looks tidy ...making a virtue out of necessity so to speak
