Old 8th July 2009, 08:08 PM
guinea
Guest
Posts: n/a
1 - Could be the link arm (c-shaped bracketty thing), or control arms.
2 - Check the filter in the fluid reservoir and make sure it's clean. I had a similar problem and cleaning the filter made it go away.
3 - Probably a dirty sensor, pop it out and clean it
4 - Probably a stretched wire in the sensors, if it does it when turning the wheel or going over a bump, then it's more liekly the wire. Fix details are on audipages.com.
Well i tried to get the sensors out and there in solid....any ideas...(pop it out)..nearly broke a finger trying to get it out..
Looked at the front discs and there a little coroded on the inside face...plenty of pad
