Well i tried to get the sensors out and there in solid....any ideas...(pop it out)..nearly broke a finger trying to get it out.. Looked at the front discs and there a little coroded on the inside face...plenty of pad |
Corroded disk on the inside sounds suspicious... Should be nice and clean there, I'd get someone to work the brake pedal while you look at the caliper, could be sticking.
The sensor it a bit tight to get out, a couple of light taps with a hammer to loosen any rust, then grab (carefully) with some big pliers or mole grips and see if you can get it to move.
I need to buy some new front discs and pads/.....mine is a 98 (S) reg 4.2 quattro sport.....do they have 8 small pads instead of 4 large ones.....
and also where can i get some..euro parts..£56.00 for 2..and £55.00 for pads...is that good |
U need the 8 small pads. Might be a good time to try and upgrade; otherwise europarts or GSF would do them.
well..ive just had new discs and pads on the 8 and i also had to bite the bullit and have a new front drivers side wheel sensor...the frightening thing is seeing your 17 year old trainee mechanic son taking my baby for a test drive as he works at this garage....also amazed to see him plug the diagnostics Pc thingy into the connection point under the front ash tray and reset the ABS light......
Brought my first A8 4.2 quattro sport when I was 17 and it survived about 11k unscathed with me!
