When I went to Unit20, for not much more than the sum you are quoting, I got
2 new cam chain tensioners (around £425 each!)
2 new cam chanins
new timing belt and all rollers and tensioners (he put on RS4 rollers to boot!)
two crank case breather valves
engine oil & filter change
and a ton of other small bits.
Go to MRC or Unit20, then you know the job is a good one and you will pay less.
I specifically asked for the tensioners and crank breathers purely as preventative maintenance because I was going to keep the car forever.
