#31
When I went to Unit20, for not much more than the sum you are quoting, I got
2 new cam chain tensioners (around £425 each!) 2 new cam chanins new timing belt and all rollers and tensioners (he put on RS4 rollers to boot!) two crank case breather valves engine oil & filter change and a ton of other small bits. Go to MRC or Unit20, then you know the job is a good one and you will pay less. I specifically asked for the tensioners and crank breathers purely as preventative maintenance because I was going to keep the car forever. |
