Old 12th January 2014, 08:38 PM
Just on a follow-up to this question I posed before, which Architex_mA8tey or Mkoneman could probably help with.
Now that I've had the gas conversion done on the car, does retrofitting the rear blind involve any work or access requirements from the boot area, as mine is now rather cramped:
If it can still be done, any help on the cabling required would be a bonus, as that is probably my biggest concern to doing it right.
Unfortunately yes. You will need to unbolt the speakers, from the boot, as they need to be unplugged and removed to remove the rear parcel shelf.
To access these screws you need to remove the plastic speaker covers attached to the boot roof.
Also, the frame carrying the rear blind is bolted to the boot roof, so you will need to unbolt it from the boot. There should be 3 nuts to remove.
