View Single Post
Old 13th February 2014, 07:24 PM
Hi
Ian - i'm so glad I didn't make a change when i first got it...i wouldn't change it for the world now!
PhYcHe - They are Delta Mics hub centric wheel spacers. They are made of steel rather than aluminium alloy - unlike my previous Eibach and H&Rs which were are about 2lbs lighter but i wasn't that bothered - the important thing for me was that it had the TRACK+ configuration where you first bolt the spacer to the hub and then the wheel on top rather than replacing the bolts with longer ones.
So another quick update on mods...I finally got around to fitting the CREE LED P21Ws and 501s, wiring and coding them as DRLs and OMG, what a difference. The photos don't quite do it justice but the difference is quite remarkable. It may be one of my favourite mods so far. It makes the car look much fresher, newer and up-to-date...and it's not really that old yet either!
I wanted to thank M-A8 for his DRL retrofit 'how-to'
Cheers,
Oli
Before: (Sorry for the crummy pic...it's the only one i could find...doh!)
After:
Great stuff Oli
What a difference !!!
By the way, where is the S8 grille mate ???
Can't wait to see it on your car.
You could consider this http://forum.a8parts.co.uk/showthread.php?t=7526
