Old 30th March 2014, 09:23 AM
Originally Posted by CLKFAN View Post
What are your rear offsets with the 21x10.5?
And I noticed you have 295/25/21...is the rubbing you're speaking off tire rub or rim rub? Reason being is because I'm planning to run 285/30/20 which will stretch a little on a 20x11.
Offsets at the rear are ET35 from memory, I'll check when I'm next with the wheels as they aren't on the car at the moment. The hub was slightly thicker than the original 18" quattro sport wheels as I had to use longer bolts by 5mm too.
Yes the rubbing is just very minor tyre rub rather than rim rub
