Originally Posted by Architex_mA8tey
Hmm bit of an unknown I think, I've got 21" x 10.5 on the rear of mine bolted straight to the hubs with no spacers on the back and it's about as tight as I'd want to go, doesn't rub unless extremely loaded etc but it's close so If I had to guess I'd say not.
What are your rear offsets with the 21x10.5?
And I noticed you have 295/25/21...is the rubbing you're speaking off tire rub or rim rub? Reason being is because I'm planning to run 285/30/20 which will stretch a little on a 20x11.
