Old 28th May 2014, 07:19 AM
Thanks for those observations, and yes I'm still getting it at times.
The thing is it goes away immediately if I blip the throttle, so no need to do that procedure. And I have done the TBA process (using VCDS) a while back, it all went smoothly and nothing really changed.
Is it possible to access the throttle body directly on the car and give it a bit of carb cleaner squirting there? I'm not really quite sure where it is.
The air pipes I'm pretty sure are fine.
