Thanks for those observations, and yes I'm still getting it at times.
The thing is it goes away immediately if I blip the throttle, so no need to do that procedure. And I have done the TBA process (using VCDS) a while back, it all went smoothly and nothing really changed. ![]() Is it possible to access the throttle body directly on the car and give it a bit of carb cleaner squirting there? I'm not really quite sure where it is. The air pipes I'm pretty sure are fine.
Well it happened again today, when the car was totally warmed up near the end of an 80-mile run.
![]() I was leaving the M25 after several miles at "motorway" speeds, down a reasonably long slip road, so braking gently for maybe 200 metres to a roundabout under the motorway. At the bottom I had to come to a complete stop as there was traffic (one small car!) on the roundabout, I then entered the roundabout and took the next exit, following it. As I moved off I could tell it was misbehaving again, but it's a very quiet junction with nothing behind me or even in sight apart from the car I'd waited for, so I just lets things develop. It moved off quite gently, even though my foot was down a reasonable amount, revving up to maybe 3500 before changing up a gear then carried on the same. It was a bit like driving a manual car with a slipping clutch. It was in full auto mode so I don't know what gears it used. After the gear change I got bored and "blipped" the throttle, reverting everything to standard behaviour and overtook the little car (empty dual carriageway with 70 limit). Does this give any clues anyone can interpret. Fuel today was Sainsburys "Super" (97?) as we had a 10p off per litre voucher to use!
Today I replaced the Fuel Pressure Regulator, as discussed in this thread: http://forum.a8parts.co.uk/showthread.php?t=8351
I did buy a "cheap" Meat & Doria one (MD75013) but am prepared to get the OEM Audi one in due course if that is unsatisfactory. Although I did release the pressure by undoing the 17mm nut on the fuel feed pipe it wasn't actually pressurised, though the car had been unused for nearly 2 days and it was in the cool of the early morning. Getting the old FPR out was a bit of a struggle, it was very tight. Mole wrench to the rescue, with lots of wiggling and rotating. The new one went in fairly easily with just a firm push and a twist. Turned the ignition on and could briefly hear the fuel pump refilling the unit until it stopped. No leaks evident so started the car and it was fine. Went for a short drive and all seemed OK and suitably brisk, but the symptoms are intermittent so only time will tell.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 1st July 2014 at 09:19 AM. |
is that Meat & 2 VAG?
Hmmmm, well it's a bit different, but I've only done a handful of short runs (1 to 3 miles).
Once moving it seems as normal, but: Starting is different, less "instant" and in one case (when warm) took a few seconds to catch. What are other people's D2's like to start? I've noticed one possible brief "higher revs but sluggish progress" event after pulling out at a T-junction when the car was warmish from earlier use but had only been driven about 200 yards that time. Starting, after I changed the coolant temperature sensor, was always quick and "violent" with a short burst of high revs (over 1500rpm) before quickly setlling down to idle. Now it takes a bit longer but just goes straight to normal idle speed after a tiny initial blip at maybe 1000rpm. Maybe fuel pressure was too high before and isn't high enough now? But "on the road" it's as responsive as ever - I had a little "play" this morning to check. ![]()
Have been reading this thread and noticed that no one else seemed to experience a similar problem. Since the meet in June, I've been focusing more on trying to sort out my garden and have been not paying attention to the car. I was out the other day, and experienced the exact same symptoms. I live down a very rough lane so I tend to crawl up it anyway. When I went to move onto the road, there was lots of revs but very little movement. It was almost as if you were driving with the handbrake on. It was only a short 4-5 mile run, but I noticed the same sluggishness several times, usually around junctions. I know I still have issues with SAI and fuel mixtures, but the one thing I did discover was that I was low on oil. Very low in fact, as it was just below the minimum mark (told you I hadn't been paying attention to the car). Anyway, I topped it up and the following day when I was out on another short run, it was as responsive as ever. Don't know if this is significant or not, but as you've experienced this on a number of occasions, it if was solely a low oil issue, I'm sure you would have spotted it before now. Mine is also LPG, so it doesn't appear to be fuel/petrol related.
![]() I've recently had a full major service (cam belt, water pump, the WORKS) so would be very surprised if the oil level was wrong. No warnings, though I haven't checked it lately.
Well, I've done quite a few short journeys today and all was going well, even at places that "often" show symptoms. The car was really quite "sprightly".
Then I did the short journey that is almost guaranteed to give problems and..... ![]() To explain, I leave my house (which is on a corner of a side road so there's a bit of reversing and wiggling initially) and drive "down" my road to its end, some 350 yards downhill in a 30mph area steep enough to require minimal throttle or braking until stopping at the end where it joins a main road. I then stop and turn right (mostly) onto a single-carriageway "A" road (still 30mph) and very often get these symptoms. It's slightly uphill and a fairly busy road so you need "reasonable" throttle, though this evening the road was empty so I didn't rush. I drove about 200 yards with the engine revving around 3000rpm at under 30mph (and at least one gear change) before I got bored and "blipped" (released and repressed) the throttle at which point it reverted to sensible behaviour, pulling well around 1500/2000rpm. Subsequent journeys this evening have been through very similar junctions (it's a hilly area) without problems. ![]()
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 29th July 2014 at 09:35 PM. |
