Old 20th June 2014, 02:45 PM
It would not let me log in using my current car log in ? It seems to only accept the log in of the donor car ? ....
Hi Guy.
Compatibility issue as mentioned before??
Could you post the year of your car and part number of the module you've fitted and I will check if it's compatible with your car.
LWB A8 4.2 Petrol it's all I know so just the year and that should be enough.
Do you know if the part number of the donor's module is exactly same as the one from your car??
PS. Cheers Jim for clarifying Guy's/David's name
